Hand made special tools we end up making
Rear drive shaft pusher as drive shafts always give me grief of some kind on way out and I hate using the hammer
Remove hub and backplate
Screw "legs" in diagonally across the bolt holds that did hold the back plate.
Press in centre threaded part till itnestles in the end of the rear driveshaft, it locates nicely into the machines centre point
It will gently push out the drive shaft (assuming you HAVE disconnected it from the transaxle! )
it also doubles as a crankshaft pully "puller" as it will thread into the two 5/16" threaded holes in the cranksaft pulley and by same method of the inner threaded bar gently pull the pulley free of the crank, spacing a little tight so need to slowly losoen the crank pulley nut few threads at a time so it has something to pull against but works fine.
The things we do !!!
