Heater Blower Motor Solution - IMProved Alternative to Factory One
I know, bad pun, over used and cheesy but hey still fun
The overhaul of the standard heter blower assembly can be seen here however it is effectively just a fan in a box, better alternatives exist and one of these solutions is to drop in a bilge pump fan, better CFM, slightly less current, full plastic and sealed against water and moisture, after all it pumps water !
Details of the motor itself, dimensions and the modifications needed to make it fit. All the changes are internal, externally the motor looks like factory (just better ).
It is important to cut as shown, this motor is the larger one of choice for this mod and it will fit in almost perfectly as an interference fit with no foam packing or other stuff needed.
I will add the source when I find my original FB write up which included the supplier links.
So here we have the same as before, we need to take the shell of the blower housing clean de-rust and coat it,
I chose a really tacky quick drying paint on this one and just brushed it on, the times spent to setup the spray area anc clean guns was not worth it.
So like a standard rebuild we now have our "ingredients"
So prepared as we are an the prep/cut list from the start of this article we move ahead with modifying the pump itself.
NOTE OF CAUTION
Do not ever assume anything new actually works, test it first and not the direction of air flow and put big black arrow on side, !!
And we have slice and dice time.
See next post for more ......
NOTE OF CAUTION
