Well Imp gauges are not a mystery, nor are they truly electronic devices, quite the opposite they are primarily mechanical devices, no electrickery. Mechatronics is perhaps the term now days.
If you want to delve into how stabilisers work and so on you can see more here, some of which is repeated in these videos
MORE ON STABALISERS HERE
Now.
These videos are in 2 parts, the first covers the stabilisers, gauges and how they work. Not complex and mostly done on my very messy work bench and although I have never had time to tidy it up it was fantastic to have the 1/2 hour or so enjoying the work.
Part 1 - How things are wired and how they work.
Thats the pseudo science covered
How does this work in the car. Well you have 2 ends to test, you got to start somewhere
Toward the end of the video we cover a specialised tool (
watch and see) that can be used to test the gauges in the car, remove wire from sender, connect to tester and then to chassis and off you go.
Needs to be done with ignition ON and you need to pull the +VE on the coil or if you are unlucky and the points are closed you will bake your coil. You have been warned.
Part 2 - demo and in car testing
Enjoy
Now.
Enjoy
