Both of these are easy enough (and cheap enough) to add to an Imp so why not. Add an inline fuse to the live feed though.
Do NOT be tempted to use the Imps flasher unit and just a switch although that is also easy enough to do, the flash rate is set by current at a set voltage for 2 x 21W lamps, if you then want to drive 4 x 21W the rate of flash will change.
These are from Auto Electrical Supplies
Kit 1- Lucas Pull Switch Style
Here is one the same as I fitted to my own car. Bob Hawes also fitted same one. Lucas SFB3000 Hazard Kit
HAZARD KIT 1 HERE
Really easy to fit, 12V live fused feed, indicator stalk, chassis, done. Need to add 6.3mm spade style connectors so put them on your list
Kit 2- OEM - Rocker Switch Style
I fitted this style to my car originally but after installing I felt it took to much space and fitted Kit 1
HAZARD KIT 2 HERE
Note that the little car image does not light up, it is just a decal, the switch however does. I had to fit an LED one to mine as I thought it was not bright enough.
Kit 3- OEM - Toggle Switch Style
Never fitted this but this is effectively same as a DIY out the spares box would go ! and you just have to love the simplicity.
If you want to buy one fair enough, this is really as simple as it gets
HAZARD KIT 3 HERE
Has that gorgeous toggle switch and period look about it that the rocker one simply does not pull off (more 80s)
Plenty connectors INCLUDING piggy backs so some thought went into this !
You can pick the flasher unit, standard or LED
For later cars with round clocks, you can use one of the bays of the switch panel to the right hand lower side of the dash, all you need is a double pole switch, or drill the blank and fit the toggle/warning lamp.
Unfortunately you will need to tag into the wiring but do this properly. Do not use those horrid blue thinks that cut strands as the crimp, these are not suitable for stranded wire as far as I am concerned
NOT THESE - NEVER USE THESE
Used to be the alarm installer and DIY spotlight adders evil tool of choice back in the day, was horrid then, still is.
Having fitted BOTH solutions, if you use some of these with a binnacle dash,
very little needed really as the wiring for the indicator lamps is already at the rear of the stalk and the feed is behind the ignition switch on binnacle cars. Totally reversible in minutes
Fuse wise I usually fit 10A in one of these, it also saves making up the ignition barrel to switch lead
Farewell Comments & thoughts
Now back to the DIY one in Kit 3, you just have to love the look.
Any rocker or toggle switch will do as long as it is double pole single throw. Same as rocker switches used in MK 3 and will fit in the switch bank, perfect. Indicator can go anywhere.
The installation method and design is all the same, there is nothing innovative in this article, below is based on the principle and its the same and chances are any long term car owner (or Boat owner Roy McBride) has parts in the box for this.
!2V live feed required as the lights should function when ignition is off.
MK 1/2 Binnacle, back of ignition switch
MK 3 Round clock, back of ignition switch.
12V live feed to inline fuse holder, easy as you can just tie wrap holder to harness
From fuse holder to flasher unit (LED or standard, your choice) do not use flasher warning lamp terminal if it is a 3 pin as the unit will see a GND connection and start to work !
From flasher unit to two of the poles (common ones if change over) on the switch, this provides a fused 12V feed on both poles of the switch.
From normally open poles of the switch, one goes to each of the left and right hand lamp circuits
MK 1/2 Binnacle, back of indicator stalk, use piggy back connectors and sleeve, plug and play
MK 3 Round clock, back of ignition switch. Not having ever owned a late car, it looks like a cut in wiring is needed, not too onerous.
This is the crude, not illuminated switch version. Adding the indicator is not difficult either is using a 3 pin flasher relay. I will leave that part for you to comment on.
Drawings available if needed
Hope you enjoyed the waffle !
- That is why the flasher kits have a dedicated relay.
- Again, note if you use LEDs you need to consider the flasher relay as you might need to change it if it fails to flash or rate is terrible.
HAZARD KIT 1 HERE
HAZARD KIT 2 HERE
HAZARD KIT 3 HERE
