The Imp has always had a weak spot as far as i am concerned which is the method by which the high current path gets connected to the engine.
Default is a piece of braided strap at the transaxle mount which has been under their for years and likely the terminals have been flattened/beat to heck.
End result is folks can be seen to add "ground" wires from the battery to the engine block to chase down ignition problems.
However when the actual "connection" goes faulty your high current path for the starter what happens to the little wire you added for thos "ignition issues" yip meltdown and fire !
Lovely eh ??
My own solution is to make th high current path for the starter (and ignition) seperate from the car and double up everything.
Original Imp battery terminal wire is 16mm sq at best and chances are VERY old so not as good as wehn new.
So time to make some new ones, this time 25mm sq braid and crimped on terminals between the battery and engine direct.
First the one for the engine direct
And then installed as you can see, between battery and block.
DO NOT USE THE TRANSOM !!! as an intermediate connection.
And then an extra two leads,
One 25mm sq lead from the battery terminal to the chassis leg
Second 16mm lead from battery terminal to the inner wing (factory point)
Lead specifications I used
Lead 1 - Battery Terminal to Engine Block
25mm sq tinned copper braid - 500mm long
25-8 crimp terminals - 2 of these, the part number measn 25mm sq cable and 8mm hole
Crimped both ends, lubbed up to be water resistant and then covered in heat shrink sleeve
Lead 2 - Battery terminal to Chassis leg
25mm sq copper cable PVC insulated - 380mm long
Crimped both ends and both end witha little lube then covered in heat shrink sleeve
Lead 3 - Battery Terminal to Inner Wing (Factory point)
16mm sq copper cable PVC insulated - 180mm long
16-8 crimp terminal - 1 of these, the part number measn 16mm sq cable and 8mm hole
- Attached to the chassis leg with a 5/16 bolt, i opened up an existing hole and installed a Rivnut
16-6 crimp terminal - 1 of these, the part number means 16mm sq cable and 6mm hole
- Attached to the inner wing using a 3/8" bolt same as factory
Crimped both ends and both end with a little lube then covered in heat shrink sleeve
Deed done
These leads can be procured online from the shelf or custom made.
Lovely eh ??
Deed done
