Steering column
  • Gary Whitaker
    aka Tiker
    • 15 April 2020
    Steering column
    Sorry if this is a daft question Is there a grommet in the body where the inner column and the rack come through the floor.
    best regards Gary
    Good question Gary as I am in the process of fitting my steering column and I cant remember there being one there either. Saying that it was removed so long ago.
    I was actually thinking of cutting up a piece of rubber with a suitably sized hole in it for the column and use it like a gasket against the bottom of the outer column tube.
      Correct fellas, no grommet or even a dust cover, reason why the insides of those get so crusty, seen plenty rot out the tubes at bottom.
      I fitted a bit of neoprene as a dust cover/gasket and threw some grease around the shaft, ugly but at least a bit better, surprising more crap dows not get in their.
      Next time I do it though I was thinking of using one of these door bottom draught excluders with long bristles and forming it into a ringaround the shaft, would work as a retrofit as well
      Some good quality foam greased up just bunged in the hole works as well (my previous solution)
      • Gary Whitaker
        aka Tiker
        • 15 April 2020
        Thanks I'll do the same
          Never too old to learn something , EXCELLENT !
