Next you put back the 3 sliding keys unfortunately I forgot to take any pics but it's described well in the manual just make sure the bottom of the clips are not resting on the inside of the key I had to grind a little of mine if there are any marks on the OD of the clips stone smooth you can't get them new so you have to use what you've got
- Likes 1
They should now push through with a click as the middle ring drops into the outer groove then push back with the same pressure .
Be careful with 1/2 sliding sleeve as it only has one outer groove and if you're not careful it will push straight through and the clip will spring out ? everybodys must have done it at sometime don't forget to oil as you go, not to much
- Likes 1
