Nice work Gary, now we can move around again I know where some grearbox bits sit, if they are free to grab I will bag them for you, will be an extra box to compare although i think the bellhousings and shaft is missing
Anything is useful I think we've got to that time where we have to be careful what we through away.
The preload on the rear pinion head bearing came within the limits and it had no shim's in if you remember the manual said it should have so they must have issues holding size on the bearing housing and it was just accounted for on assembly just like any normal engineering shop of the day
Hi ok now to start building the main shaft because we are fitting new bearings we have to recheck the the selective washers am also fitting new bushes as mine were worn .
In the pic's you will see old bushes as it's just to show how it's done ,this is a later box so no 3rd selective washer.
We use pinion head tool again for this
1st fit the bearing
- Likes 2
Now check the preload as per your manual for new bearings 6 to 12lb.
if you've never done it before it feels very tight to turn but you need it for the rigidity of the box and it will drop once you've covered a few miles .
A new gearbox needs running in just like an engine mine came out at 10lb I had to go.004" thinner than the original shim .If you remember the rear pinion bearing housing had no shims and the manual said I had to make it up to .032" that would have brought it out of tolerance for the shims to correct ,so they must have had problems holding size at the factory . conclusion is if you change the rear pinion bearing put back the same shims you took out.
- Likes 2
