I had time today to do a little experiment I wanted to see what interference fit the bearings are
please note that this is just my experience of breaking down and rebuild of the transaxale , I in no way saying this is how you should do it yourself or implying that I am an expert, I am not, but skills are getting lost and the manual sometimes not the easiest to follow
If I can show some photos as I go then it will probably help someone else.
Back to the experiment the manual say you should heat the box to 100 degree before removing the bearings so is it really necessary ?
I measured a new bearing outside diameter and set my bore clock to zero
First photo shows it at room temperature 20 degrees
The bore clock is in mm .01 division so just under .05 mm .002"
On 54 mm which is the bearing size I think you would damage it cold
Now at 100degs size is over .04mm .0016"
So my conclusion is they should go in easily at 100 drgs but you will have to be quick the heat transfer will soon make them grow
Best regards Gary![Click image for larger version
Best regards Gary
