At the time i was looking for fuel senders i found that out the 7 or so I had lying around all had issues on the winding so would be flaky at one point, the wiper / rheostat is worn in nearly all of these and NOS ones are getting expensive.
New ones are still available, Bob Allan at Club Spares can supply however they feel flimsy.
So I bought one of these and so far resistance wise seems same as Imp, guage tracks very well
![Click image for larger version Name: 0021859_fuel-tank-sender-6-hole-flange.jpg Views: 402 Size: 73.1 KB ID: 5912](filedata/fetch?id=5912&d=1666434032&type=small)
This has the added benefit of a LOW FUEL terminal as well![Cool](https://www.hillmanimp.org/core/images/smilies/cool.png)
The PCD is a perfect fit
![Click image for larger version Name: 20200412_124054.jpg Views: 174 Size: 13.9 KB ID: 5913](filedata/fetch?id=5913&d=1666434032&type=small)
![Click image for larger version Name: 20200412_124106.jpg Views: 187 Size: 213.5 KB ID: 5914](filedata/fetch?id=5914&d=1666434032&type=small)
So PCD FIT - YES
Resiatnce range High to Low - OK
Low Fuel warning - Mod time - BONUS in adding just one wire, how accurate, to be seen
Best bonus is price, Only £24 plus shipping for a new one.
Unless you are completely proper resto-orientated it seems a good deal.
Only down side is you have to bend / set the new float level / angle by hand first as it is "universal" however after that all gravy as they say.
The new replacement "originals" I had to set the float height on anyway !
I have one to fit in DDG so will report back when actually fitted (and working)
So PCD FIT - YES
