Franks exhaust manifold
    Many of you have these , i fitted both mine a good few years back .
    So fitting .
    Fairly easy as it happens , i found the head studs lined up fairly well and it fitted OK .
    Manifold outlet pipe did need bending down a tad and it also sits a lot higher than say a Janspeed did , This means there is a limit to the silencer length otherwise it will hit the rear panel . Max silencer length is 14 inch and even then only if you cut a bit off the manifold. A 12 inch box is the ideal and no more than 4 inch in diameter , you can of course fit an oval box .
    I had to make the exhaust hanger and clamp on both of mine , also rubber mounted it as . anti vibration
    ALWAYS adjust the hanger to match the exhaust bracket your fitting - in other words dont try and bend the exhaust up or down to fit the bracket , that causes major stress to the bracket , box and manifold - not a good thing.
    I fitted 90˚ bends as tailpipes on mine but straight will fit OK
    Singers set up
    Vuskys / Husky / Van set up - longer tailpipe - Singers on the right
ID:	4050Click image for larger version
    Manifold on the engine ( Vuskys )
    Home made rear hanger and rear box clamp
    I used an old inner track rod end as an exhaust bracket - rubber mounted
    You can see how high the box sits - hence the box length restriction
    Another view of that rear hanger - the whole exhaust set up is stainless , clamp in pic was temporary
    home made clamp
    The set up on the Vusky / Husky / Van
    • 4843
    A message from Frank on the second (or is it third) generation manifolds
    Frank Wrote : Thank you Dave Lane. Yours were early type they have since been slightly improved...and now available highly polished. They were made high so the young brigade could lower their imps but also were made to take the offset back box which then cleared rear transom.. I currently have made and sold 175 of them and have 15 left........
    Some images of the latest ones !
    • MartinSullivan
      • 18 January 2020
      • 16
      Ooh they look lovely - how do I go about getting one of these ?
        Contact Frank Schoenberger via facebook
          • 4843
          Email Frank direct (or Roger Gill keeps stock in UK), they will both get the email
          franks_manifolds@hillmanimp.org
          Or Franks UK stocking agent
          roger.gill@hillmanimp.org
          (Masked address to suppress spam)
