First clean clean clean, every part from top to toe. Assume he head has already been done as those are small enough to look at easilly.
The block is a bit of a lump.
Parts used on this rebuild were
New head bolts
- Spares from another engine.
Oil Filter
- Wix filter from motor factors, equivelent to the Volvo one taht is popular.
Bottom end gasket set
- Payen NOS bottome end set. Unfortunately this had shrunk and did not fit the stud pattern.
- Remanufactured from Bob Allan at The Imp Club Spares service (membership required to use)
Top end gasket set
Double Lipped Timing Cover Oil Seal
- A tip from Pete Fitzgerald and sourced by Bob Allan at The Imp Club Spares service I used this in preference to the single lip one in the bottom end set.
New Piston Rings
- Standatrd rings from Ben Boult - Corley Conversions
New Main Bearings
New Big End Bearings
Out wash and wash again, full pressure steam blasted
New head bolts
Oil Filter
Top end gasket set
New Piston Rings
New Main Bearings
