Well the devils hands were at work today again
plus I had to wait on the paint drying on the hatch
The oil capacity externsion was easy enough but on these it was desired to move the oil filler plug from "front" to "back" in other words reverse what rootes originally did and make it like a MK 1
Bob Picton kindly supplied the machined bosses and the sumps so I could have something to beat up and work on
First cut the end section out, not fully as these will be used with rear rad in palce so still needs the space for the coel and the rad itself.
And off with the rear fille plug as well.
Then drill front for new drain plug locations using the new bosses.
And of course we should not forget on its apex the sump runs to the rear drain plug location so now a trim along the apax and some rough re-shaping to avoid gettinga pool of oil that will not drain
And that should be most of the roughing work done
maybe
perhaps
If its a good day tomorrow I might get some welding done and get at least the drain plugs and the apex seam/old plug location sorted out
Time to check the weather forcast ! Petowner
