Cylinder head casting numbers and valve sizes
This topic is closed.
  • Cylinder head casting numbers and valve sizes
    Head Number
    HEAD NUMBER COMMENT VALVE SIZE INLET VALVE CLEARANCE INLET VALVE SIZE EXHAUST VALVE CLEARANCE EXHAUST
    7010031 VERY EARLY MK 1 HEAD 1.064 " *** 0.005 " +/- 0.001 " 1.010 " 0.007 " +/- 0.001 "
    7010128 LATER MK 1 HEAD 1.064 " *** 0.005 " +/- 0.001 " 1.010 " 0.007 " +/- 0.001 "
    7010133 EARLY MK 2 HEAD 1.202 " 0.005 " +/- 0.001 " 1.064 " *** 0.007 " +/- 0.001 "
    7010171 LATER MK 2 HEAD 1.202 " 0.005 " +/- 0.001 " 1.064 " *** 0.007 " +/- 0.001 "
    71981533 * LATER " L4 " HEAD 1.202 " 0.005 " +/- 0.001 " 1.064 " *** 0.007 " +/- 0.001 "
    7010107 * EARLY SPORT HEAD 1.276 " 0.007 " +/- 0.001 " 1.064 " *** 0.014 " +/- 0.001 "
    7010180 * LATER SPORT HEAD 1.276 " 0.007 " +/- 0.001 " 1.064 " *** 0.014 " +/- 0.001 "
    * NOTE : THESE ARE FITTED WITH SPORT CAMSHAFTS AND CARRIERS AND HAVE AN OIL DRAIN FITTED TO THE HEAD ( NO VALVE SEALS )
    *** NOTE : ALTHOUGH VALVES SIZES ARE THE SAME THE INLET AND EXHAUST VALVES ARE NOT INTER CHANGEABLE
    Thanks OliDP72
    As Oli pointed out there is also a 7010162 head which is as rare as the 107.
    I am unsure of the valve sizes but I would think they will be the same as the other port heads and will update the table when I do.
    J
