While shimming Pauls first 107 head with 1.4 valves and so on we had to have work done on the spring tops to be able to shim them but assumed that was due to the valves used.
With no shims there was no clearance. As said head had some serious work done on it and likely had a different cam but if it had had a higher lift it would have been worse (unless it had a billet carrier to match) it is a mystery
Pauls head now needs work (guides mainly) so he has borrowed my "standard" 107 head but after dropping the sport cam/carrier off his 533 head onto my 107 the shim sizes are once again really small, a lot below 62 thou but consistent.
I wish I had kept the original cam/carrier on this head now as it cam off a running engine.
Did rootes make any special carriers, lifters, spring tops or even valves for these original 107 heads not listed in the parts manual? I am used to seeing more along the lines of 85 thou and up on most heads including 180's
In fact we don't have any shims small enough now, plenty larger sizes but nothing this small.
Looks like we will need to have some made
