MK1 Singer Chamois
As the ones fitted ( Nexen ) had hit 10 years old ive had the front tyres changed . Ive got Yokohama A539s fitted as on Barnaby ( 175/60/13s ) ,
Fitter was stunned as to how good the wheels were - only 5 grams out on the passenger side
Both mounted correctly too with the red dot by the valve ( but only if you have a red and yellow dot _
Info here
Have you ever noticed red or yellow dots on the sidewall of a new tyre? Here we explain their function and how to use them properly. Read on.
Singers dipstick ( which happens to be a Van / Husky one ) has a habit of slowing coming oot the tube , its vibration not excess crankcase pressure , My brass remade dipsticks seem to be worst for this , most likely not enough spring in the brass .
Anyhoo ive gone back to a steel factory dipstick and invented a spring effort to hold the bugger in place - wont work its way out now
Also cleaned up the alternator supporting doofer wot I made .
So a heatwave and a car with a reputation of boiling , warping heads , headgaskets etc etc ---- not a good combo except a well maintained engine and cooling system should cope fine .
So as a trial i stuck some Thermax heat sensitive stickery things on the rads of both - these will tell you what the temp actually is and not what the gauge tells you ( although both mine are bob on ) .
These just give a " max reached " temp so its not a gauge but a good indication of the hottest it got , they dont return to how they were but stay on the indicated max reached .
Anyhoo Heres the results of both mine - heater off obviously or we would cook - first off the Singer in 27˚C after a 10 mile thrash .
Second is Barnaby after 140 odd miles to the full English plus 40 odd miles this week to work and back , you can see number 4 block was just beginning to change on this so maybe 85˚C is a more accurate reading of this one
