I took Nutmeg out this morning for a local run to see if the heater would work after fitting the new nearside heater hose. Despi...
    • 9 December 2019
    • 7742
    I took Nutmeg out this morning for a local run to see if the heater would work after fitting the new nearside heater hose. Despite bleeding the system no heat and a cold offside hose. Had to fill up the header tank once cool at home so a lot of air is still in the system. Also this was her last run with the original rear shocks. There was some creaking from the back over some bumps and a bit bouncy at times. Hopefully the new ones will cure this. Photographed by the Platinum Jubilee bunting over the stream in Chilcompton up in the Mendips.
