Nothing like having the entire car apart weeks before a big event. Input shaft was wobbling as it was loose causing a failure in the gearbox seal.
I have to say a massive thank you to Andy Jones and Col Rooney!
When we thought it may be an engine seal Andy was straight on it!!! Col as usual is fantastic !!
Just goes to show that when you restore a car you should select the people you work with carefully.
