I need to remove the fuel tank in order to access the clutch master cylinder. My problem is the fuel gauge sender is not screwed...
I need to remove the fuel tank in order to access the clutch master cylinder. My problem is the fuel gauge sender is not screwed in as described by the Haynes manual. It seems to be spot welded in place.
