Is there an oil pressure adaptor for the imp engine block ? I have a sideways (brass) outlet on my engine, wich is roughly 6 mm outside, maybe 4 mm inside. Then -and thats the problem- there is a thin clear nylon pipe to the instrument. I can push the nylon pipe inside the brass but it is of course not oil tight, and is easily pushed out. I had a rubber hose „fitted“ which went over the brass part and over the nylon pipe, but it broke / became brittle.
So I am now thinking about a more professional setup - is there a standard adaptor I can order somewhere ? I guess the block thread is (maybe) R 1/4.
