Engine fitted Friday and started easily and no leaks.?. Ran at Curbs today, engine running great. Slight problem on first run, f...
  • Engine fitted Friday and started easily and no leaks.?. Ran at Curbs today, engine running great. Slight problem on first run, f...
    Engine fitted Friday and started easily and no leaks.?. Ran at Curbs today, engine running great. Slight problem on first run, forgot to tighten the front left wheel nuts - oops. At least it gave the engine an easy time as I liked back. No damage, just rattled a lot. Ran the engine with max 15 psi of boost and it ran perfectly. New turbo and intercooler seem to flow much better and inlet temps were max of 38 degrees ( used to be around 60 degrees). Managed to win the class, mainly by getting a good time in when it dried out a bit, whilst my main challenge spun. Really happy that I have finished an event with all the water still in the engine ( better than my last 5 events).
