Stan : 1972 Hillman Imp Deluxe.
  • #16
    You can name one Laurel and The other one Hardy for this bit of slapstick, sledge hammer for a kingpin and they broke the vise !
    Slapstick indeed, much in common with working on imps
    Fella on the left is our health and safety fella !
    • #17
      Good to see you on here Andy , was going to ask if they were the red high intensity led bulbs as rear fogs, but already answered that one , l was thinking of putting some into Lucas rear lights which you can use as reversing lights so effectively two bulbs in one unit ,so dual usage , reverse or rear fogs. haven't sussed out the problems as yet .
      Never tire of seeing pic's of Stan .
      • #18
        I did that mod many years back. They are actually placed inside steel tubes which go right through the rear crossmember and are welded all round then ground flat on the visible side. Used in inclement weather, and turned on for the amusement the MOT tester
        Andy G
