Weather was OK so some work done today outside
    Started on the two extended sumps Bob Petowner as I was outside cutting metal anyway
    It is unfortunate but i cannot do these things in the garage. All the tin bashing needs to be done outside
    A mate of mine had an axle stand slip and popped the chassis leg a little and look a bit crusty.
    What was a 1/2 inch crack turned into replacemnt of nearly 200mm of chassis section on the Landy TD3
    All cut out still a tad crusty but rest was solid when hammered and ground back, getting thinner but plenty meat on whats left
ID:	17340 Click image for larger version
    And plated up and coated
ID:	17342 Click image for larger version
ID:	17344 Click image for larger version
    And the coat of Ed Cs repair solution and job is a good un.
ID:	17346 Click image for larger version
ID:	17348 Click image for larger version
    Lovely to hear that John BIG THANKS
    Are you still at 16 M------Drive
    Posting Spanner .
      Bob, yes still here
