Two engine lid stays
    As you probably know all Imps only had one from the factory.
    Early ones were wire and later ones flat sprung steel and theres problems with both.
    Early ones work OK but dont hold the lid up too well if its windy in the wrong direction , they do however seem to last forever unlike the later sprung steel ones which have a habit of breaking at the base . Also they can be hard to lock into place putting strain on the engine lid and its hinges . Im positive the change to the later sprung steel ones was bought on by folk wandering into the dealers with a nasty bump on the bonce
    So i hatched a plan to fit two early type stays on the Singer - one each side .
    Didnt turn out as easy as i thought because apart from the spring itself everything else is handed wrong.
    Come the end I had to make both mounts from scratch including the steel bobbins the spring fits too and locks into .
    Still a few hours making a few small brackets and a bit of time on a lathe resulted in a real success
    Click image for larger version  Name:	IMG_1647.JPG Views:	22 Size:	2.15 MB ID:	4808
    The one and only R/H engine lid stay
    Click image for larger version  Name:	IMG_1645.JPG Views:	14 Size:	2.20 MB ID:	4807
    And then there were two
    Click image for larger version  Name:	IMG_1646.JPG Views:	14 Size:	2.07 MB ID:	4809
    now on " da list" ?
      now on " da list" ?
      Da list gets longer
        Da list gets longer
        Yes but lots of GEMS Well done and THANKS Dave
          Da list gets longer
          nearly getting as long as Helens to-do list for me.
