Radiator expansion bottle
  • #16
    I've got it now, so the tank is filled to the brim and it's the expansion when it heats up that moves it into the expansion tank not the pressure.
    I wouldn't have thought it would be able to get back from the tank to the radiator with the cap. Didn't know about the internal valve in the cap.
    Here you go , its the low pressure valve in the middle , lets coolant back in without moving the main seal , on my cap on the bottle this is jammed open - non pressurised but leak free
    Click image for larger version  Name:	unnamed.jpg Views:	0 Size:	19.8 KB ID:	3831
    • #17
      Paul Conroy has got the bug Dave, was just up with turbo 875 MK 3, an expansion bottle has appeared
      • #18
        Click image for larger version  Name:	image_3826.jpg Views:	3 Size:	3.07 MB ID:	9662 Thanks for the tips Dave, here is my attempt. Does the height of the bottle matter?
        • #19
          As long as its below the top of that rad it should be fine , pipe should be right to the bottom off the bottle , you will see it working , fills up by an inch or so when hot then goes slowly back to the cold level as it cools
          • #20
            Thanks Dave, might be. Little high then. The water level when hot is lower than the top tho. Will drive it around and see what happens.
            • #21
              I like these old plastic bottles that have that sort of oldish look to them, look like they should be there.
