Ever noticed if you brake hard in an Imp with 1/2 a tank or more fuel comes out the overflow pipe and the car stinks of fuel . Ever wondered how much would come out if you sadly fit someone and the fuel filler pipe splits . Well ive not hit anything but i recon it would be a lot .
Anyway this one way flappy tank valve solves all the issues , mines been in since 2016 with no ill effects other than you need to fill up a tad slower .
Valve is for a MK2 / 2.5 Mazda MX5 - part number GE4T- 42 - 270B , Available from Mazda or i got mine from here
http://www.mx5parts.co.uk/fuel-filler-r ... -2643.html
You also need the filler pipe as this holds the valve .
I got mine from ebay - theres usually a few for sale .
You also need a rubber adaptor , try as i might i couldnt find the exact size to fit our tank so went with this one , part number HRED50.
https://www.carbuildersolutions.com/uk/ ... id-reducer
The problem with not finding the correct outer diameter meant the necessity to make an adaptor to the following size. inner diameter was made slightly smaller than the 50mm rubber adaptor so its a tight fit , Rubber adaptor is fuel / oil / whatever resistant or so it says anyway
The Mazda pipe you need looks like this
Chop off this end keeping both swage bumps in place
Adaptor dimensions required , steel will be fine
Fits together like so
Standard Imp rubber fuel filler hose just fits over it with no further mods required , flaps allow the fuel to go in but close if any tries to get out , even an emergency stop with a fuel tank resulted in no fuel smell whatsoever . Flaps remaion open under normal driving so tank venting is unaffected
The bits you need
The bits you need
