Electricery fuel pumps
  • #31
    Originally posted by High_dan View Post
    Spoke to mike earlier today, he confirmed the one he has supplied me with will be perfect for the Weber 28/36. The Posi-Flo is there new design if it’s two noisy will swap it out for a carter or su one. Already have the pump so might as-well try it. Will report back soon.
    If Mikes says its perfect then it is as i trust whatever he says 100% , Sorry for my concerned posts but its best to be safe than sorry
    • #32
      Modern fuel pumps are usually inside the tanks hence why you cannot hear them. Viton tipped needle valve in a weber will take more than 4 psi these pumps are way quieter than the old facets you guys are thinking of and pressure and flow rate is correct for 998 on 28/36, everybody usually goes for facet cubes (noisy) or the cylindrical type and just buy what they see without checking out the spec so usually end up with a red top or gold top that is capable of feeding a 300 bhp rally car then they buy a regulator to control the pressure always baffled me. I use genuine mitsuba pumps very hard to find and the ones on the web are copies and expensive poor ones at that. The mitsuba on 6mm fuel lines keeps up with my 1040 on twin 40 webers 3.5 psi at carb and plumbed in series to keep pipework neat and no difference which one you run either sucking through standby pump of pushing through, flow rate is more than the car can consume and the pressure is not affected. The new style facet i have recommended is not as quiet as an su pump but on a standard car with carpets etc and rubber bobbin mounted i doubt you will hear it on the move. I know how fussy you are Dave with road car stuff and making your imp reliable and user friendly, quiet, smooth etc. Using modern kit but keeping the tradition of the car it is why you are my test mule for any comp parts that i think may cross over, if you say it is horrible then i can mention this if anybody wants anything for a road car if you say it is fine apart from a slight increase in noise or vibration but ok just not for you, i know where i am when advising people.
      • #33
        Thanks mike were your ears burning! once it’s installed I’ll make a video of it running and report back.
        • #34
          Cool, Mike knows his stuff, he would not keep junk let alone supply it and the rattly facets I have experience of are indeed junk.
          Let us know how you get on please.
